sveiki. Carismoj gdi 1.8 daznokai pradejau girdet kalimo garsa toki kaip video panasu.. Mazdaug kas galetu buti? p gal normalu?
VIDEO NEMANO: https://www.youtube.com/watch?v=FMgsR-7IcoY
carisma gdi garsas
ModestasL
- PranešimaiCOLON 38
- UžsiregistravoCOLON 2013 03 16, 13:38
- AutomobilisCOLON Peugeot 406 2.0 HDi
carisma gdi garsas
Mitsubishi Carisma 98' 1.8 GDI / sold
Peugeot 406 01' 2.0 HDi / in use
- tiger_eye
- PranešimaiCOLON 124
- UžsiregistravoCOLON 2012 05 09, 14:40
- AutomobilisCOLON Galant 2.0 VI '97 4G63 sohc
- SkypeCOLON raightas1
- MiestasCOLON Klaipėda
Re: carisma gdi garsas
Kada paskutinį kartą keisti tepalai?
O šiaip tai ten po video pilna komentarų anglų kalba
pvz:
it is еру Hydroequalisers of valves . i had еру same problem for long time. I used to do all the stuff with them, to clean them few times with special chemic fluid, but it worked for a short time. I replaced them with new one "NAKAMOTO" and the problem got fixed. Dont use 10w-40oil for this engine!!!! only 5w-40 and push it to the limits regulary. Problems comes after bad gas and bad oil so it leaves on Hydroequalisers of valves lake. I am sure this information will help you out
Now Mitsubishi galant 2.0 100 kw '97 [daily]
Ex Peugeot 406 1.8 81kw '96 [crash tested]
ModestasL
Ai rimtai tepalus jau butu beveik laikas keisti seip..
- tiger_eye
Tik susipilk teisingus teipalus
ModestasL
5W-40 turiu. Rekomenduojami 0w-40. bet gerai bus ir 5w..
