exactly`Tadas` rašėCOLONTai taip gaunasi,kad gamino ta pati firma tik skirtingoms rinkoms?Roliz rašėCOLON Buvo didele firma DSM gamino mitsius amerikos rinkai ir europos. europai isejo su 4g63 o amerikai su 420A.
pamastymai apie eagle talon varikli
- rs_matrix
- PranešimaiCOLON 956
- MiestasCOLON vln
bet gaminta tos pacios firmos jeigu, tai nifiga 420A ne kraislerio, o kraisleriui, dogui, plymutui ir t.t. tieke vienas gamintojas kuris gamino ir vienus ir kitus enginusRoliz rašėCOLONbet 420A tikrai mitsubishi nekure !!! nes japonu varikliai yra zimimi taip : 4g63, 6g37 ir t.t. pirmas skaicius cilindrus, 2- degalus ir t.t.`Tadas` rašėCOLON Tai visiskai tas meistras nenusisnekejo.
2G Eagle Talon ESi
dsm ju negamino o eme is chrysler firmos. jei nemoki ieskot va prasom info :rs_matrix rašėCOLONbet gaminta tos pacios firmos jeigu, tai nifiga 420A ne kraislerio, o kraisleriui, dogui, plymutui ir t.t. tieke vienas gamintojas kuris gamino ir vienus ir kitus enginusRoliz rašėCOLON bet 420A tikrai mitsubishi nekure !!! nes japonu varikliai yra zimimi taip : 4g63, 6g37 ir t.t. pirmas skaicius cilindrus, 2- degalus ir t.t.
This information was originally obtained from the Sebring/Avenger Performance Page.
The information applies equally well to the non-turbo Eclipse and Talon, as the Chrysler 420A motor is the same. In fact, the Avenger/Sebring share the same floorplan as the Eclipse, some body & trim panels, and are built in the same plant.
POWERTRAIN
This is a very detailed explaination of the Avenger and Sebring 2.0 Engine and other subsystems!
Information provided by Dr. David Zatz, and sourced from the Allpar (Chrysler/Plymouth/Dodge Central) site at http://www.allpar.com/mopar/2dohc.html.
ENGINE SYSTEMS
- Double Overhead Camshaft 2.0 Liter Four-Cylinder Engine
GENERAL INFORMATION
Avenger and Sebring feature a new Chrysler-designed double overhead camshaft (DOHC) four-cylinder engine that is compact and light weight. Displacement is 1996 cm(cubed) (121.8 in(cubed)). The engine is slightly over square with a bore of 87.5 mm (3.44 in.) and a stroke of 83 mm (3.26 in.) Compression ratio is 9.6:1. The engine is designed to run on regular-grade unleaded gasoline.
