kokios tinka greicio deces eclipsiu 2g
ech nebutu dede viktorijus gerasijus
se gaudyk
What kind of transmission is in my [DSM]?
Table 2: 1995-1999 Talon, Eclipse and Eclipse Spyder
Specification Base model Mid model Upper model (FWD)
Eclipse model names - RS GS GS-T GSX
Talon model names - ESi TSi TSi AWD
Engine type 2.0L 2.0L 2.0L turbo 2.0L turbo
Driveline FWD FWD FWD AWD
Standard transmission F5MC1 F5MC1 F5M33 W5M33
Automatic transmission F4AC1 F4AC1 F4A33 W4A33
Different transmissions are not interchangeable. Note that 2G transmissions are interchangeable with 1G transmissions of the same model number, but 2G transmissions have different internals and are generally considered to operate much better. Usually only minor modifications are required to fit a 2G transmission to a 1G engine.
stai tavo dezes numeris F5MC1 si numeruka ivedes ji radau tik pas chryslerius
http://www.vibratesoftware.com/html_hel ... ssions.htm
taip kad kaip ir sakiau neonai saturnai vnz visas amerikonu kosmusas
se gaudyk
Na va, riebalauskas jau viska kaip ir isaiskino, o as tik galiu pridurti, kad praktiskai tie patys chryslerio varikliai eina i:
Neon;
PT cruiser;
Sebring;
Avenger;
Voyager;
nuo 97 metu (2.0, 16V DOHC) Taigi turetu eiti ir tos pacios greiciu dezes siems varikliams. O paknisus interne raso, kad tikrai bent jau sebringui ir avengeriui eina tos pacios dezes:
F5MC1 MANUAL TRANSAXLE
General Information
An all-new Chrysler-designed five speed manual transaxle is standard on Avenger and Sebring LX with the 2.0-liter engine. It has a three-plane shift arrangement with Reverse in line with Fifth gear. Oil capacity is 2.1 qt (2.0 L) of manual transaxle fluid which contains special additives to improve shift quality. Ratios are as follows:
GEAR RATIO
First 3.54
Second 2.13
Third 1.36
Fourth 1.03
Fifth 0.81
Reverse 3.42
Final Drive 3.94
Overall Top Gear 3.20
Neon;
PT cruiser;
Sebring;
Avenger;
Voyager;
General Information
GEAR RATIO
First 3.54
Second 2.13
Third 1.36
Fourth 1.03
Fifth 0.81
Reverse 3.42
Final Drive 3.94
- Pliustas
- PranešimaiCOLON 3141
- AutomobilisCOLON Eclipse 1G
paaskinkit man runkeliui ka tie gear ratio skaiciukai prie shaibu reishkia?Micius rašėCOLONNa va, riebalauskas jau viska kaip ir isaiskino, o as tik galiu pridurti, kad praktiskai tie patys chryslerio varikliai eina i:
Neon;
PT cruiser;
Sebring;
Avenger;
Voyager;
General Information
GEAR RATIO
First 3.54
Second 2.13
Third 1.36
Fourth 1.03
Fifth 0.81
Reverse 3.42
Final Drive 3.94
Zinai ta paveiksliuka su Simpsonu sunum, kur ant lentos kazka apie google ir dumb questions rasoPliustas rašėCOLONpaaskinkit man runkeliui ka tie gear ratio skaiciukai prie shaibu reishkia?
O seip, tai va, isirink kuri nori:
http://www.google.lt/search?hl=lt&lr=&o ... Gear+Ratio
Nu tai srotuos, kur ir amerikanskas auto ardo, arba per skelbimus laikrasty, kur dalim pardavinejaandriuhas rašėCOLONna jaigu jau tek zinot apie sitas masinas tai gal ir zinot ir kur rast ???:)
isivaizduok mazesnis ratukas suka didesni mazas apsisuks 10 kartu o didelis tik 1 tai gaunasi kad ratio arba santyksi 10:1 taigiPliustas rašėCOLONpaaskinkit man runkeliui ka tie gear ratio skaiciukai prie shaibu reishkia?Micius rašėCOLONNa va, riebalauskas jau viska kaip ir isaiskino, o as tik galiu pridurti, kad praktiskai tie patys chryslerio varikliai eina i:
Neon;
PT cruiser;
Sebring;
Avenger;
Voyager;
General Information
GEAR RATIO
First 3.54
Second 2.13
Third 1.36
Fourth 1.03
Fifth 0.81
Reverse 3.42
Final Drive 3.94
- Pliustas
bet tai kad cia tie skaiciukai be jokio dvitashkio, vot man ir klausimas todel pasistojo.Riebus rašėCOLONisivaizduok mazesnis ratukas suka didesni mazas apsisuks 10 kartu o didelis tik 1 tai gaunasi kad ratio arba santyksi 10:1 taigiPliustas rašėCOLON paaskinkit man runkeliui ka tie gear ratio skaiciukai prie shaibu reishkia?
- Pliustas
aha jau buvau spejes intike ishsiaiskint apie tuos ratukus-dantratukus.Riebus rašėCOLONGEAR RATIO
First 3.54:1
Second 2.13:1
Third 1.36:1
Fourth 1.03:1
Fifth 0.81:1
Reverse 3.42:1
Final Drive 3.94:1
Overall Top Gear 3.20:1
a dabar geriau na logiskai mastant tai pirma pavara mazina sukima ant 3,54 kartu o paskutine tai 5 gaunasi kad net pagreitina
