Tipo pagerina elektronikos, audio ir kt. darba ar kazka panasaus...
Net internete pardavineja laidu komplektus tam...
http://www.groundfusion.com/
Here's mine.
If you just want the grounding kit I would suggest building your own. It's easier and you can get the colored wire you desire. I got the Apexi Super Ground as well because it helps get rid of noise on your 12vdc and connects between your positive terminal, nehative terminal, and alternator. The wires in red are my addition using 8g oxygen free braided cable I got from my local sound shop.
Gal pravers kam, jei ne dar vienas... pinigu paleidimas vejais gausis...I love the people that say it's useless.
You'll run a 4 guage cable from your battery to your audio amp and use gold connectors and then when you run your ground you take another cable and just hook it to a screw close to the amp.
There is just as much current flowing through the ground cable as the positive cable but we treat the ground like it's just something we have to connect.
Little things like that are what seperates incredible sound systems from backyard jobs using zip ties.
The same thing applies for the rest of your cars electronics. The attention to detail is what seperates a high dollar car from an economy car. If you plan on adding additional strains to your electrical system like and audio system, additional lights or higher powered lights, fuel management systems, radar detectors, ipods, etc..., you need to build a solid foundation for those items to tap into.
I spent 22yrs as an electronics techincian so I know what bad grounds and contact points can do. I took one look at the main ground to chassis contact point on our car and realized it needs improvement.
