duskas rašėCOLONSveiki,
gal kam buvo parejes TPS? siaip su kompu patikrinau tai jis nieko nerodo. galvoju gal mires. o gal pati sklende ziauriai apsinesusi? Gal kas turit ta TPS?. ir CHECK engine del to pastoviai dega.
laukiu visokios info. buciau l. dekingas
THROTTLE POSITION SENSOR ADJUSTME
(1) Connect the scan tool to the data link connector (white).
(2) If a scan tool is not used, perform the following operation. 1989 models>
@ Disconnect the throttle-position sensor connector,
and connect the special tool (test harness) between the
disconnected connectors.
@ Connect a digital-type voltmeter between the @ terminal
(red clip, sensor ground) and the @I terminal (blue clip,
sensor output) of the throttle-position sensor connector.
Blue clip
@ Disconnect the throttle.position sensor connector and
use the special tool (test harness set) between the
disconnected connector.
@ Connect a digital type voltmeter between terminal @
(sensor output) of the throttle position sensor and
terminal @ (sensor ground).
(3) Switch ON the ignition switch.
(Do not start the engine.)
(4) Check the throttle-position sensor’s output voltage.
When a scan tool is used, select Item No.14 to read the
throttle position sensor output voltage.
Standard value: 0.48-0.52 V.
(5) If there is a deviation from the standard value, loosen the
throttle-position sensor installation bolt and then turn the
throttle-position sensor itself to make the adjustment after
the throttle body was removed. Be sure to securely
retighten the bolt after making the adjustment.
NOTE
The output voltage becomes higher when the throttleposition
sensor is turned clockwise.
For removal and installation of throttle body, refer to
“Engine Service Manual”.
(6) Switch OFF the ignition switch.
(7) If the diagnostic trouble code is output while adjusting the
throttle position sensor, use a scan tool to erase the diagnostic
trouble code, or disconnect the battery cable from
the negative terminal of the battery for more than 10 seconds
and then reconnect the cable. (This will cancel the
memory of the failure code due to throttle position sensor
adjustment.)
