Parduodu arba keičiu į kažką panašaus, tik 10", bagažinėj vietos trūksta
Rockrord Fosgate Punch HX2 1000W 12" subas, RFD2212
Details:
dual 4-ohm voice coils
CONsealer gasket hides mounting screws and prevents air leaks around the frame
frequency response 26-200 Hz
power range 150-500 watts RMS (250 watts per voice coil)
peak power 1,000 watts
sensitivity 88 dB SPL
top mount depth 5-13/16"
The cast aluminum frame basket reduces flex and resonance for greater accuracy, while aluminum formers allow the voice coils to dissipate heat quickly. The dual 4-ohm voice coils can be wired as a 2-, 4-, or 8-ohm load, giving you more options when hooking up your system.
Miestas: Vilnius
Kaina: 80€
Kontaktai: PM, +37060421958
Galima atsiskaityti EUR/BTC/ETH/XMR
Rockford Fosgate 1000W subas
- ZyXEL
- PranešimaiCOLON 11305
- SkypeCOLON zyxelis
