http://www.alfa.lt/straipsnis/10242114
http://www.youtube.com/watch?v=dwcE8kwTIa8
http://www.youtube.com/watch?v=hD5CRn-oMEI&NR=1
Gal posuky geriau ant kelio laikos. Arba geriau kabina,jei jie visi sesi varomi.Kevinas rašėCOLONTik nesuprantu kam tie 6 ratai? Ir dar prieki? Yra kazkoks pagrindimas? Kazkuo geriau? Ar uzdejo tik tam kad uzdetu?
Shtai ka apie tai mano WIKI:Kevinas rašėCOLON Tik nesuprantu kam tie 6 ratai? Ir dar prieki? Yra kazkoks pagrindimas? Kazkuo geriau? Ar uzdejo tik tam kad uzdetu?
Advantages
Less chance of loss of control due to one front tire deflating.
Less risk of aquaplaning due to the front axle set clearing the road for the following axle set.
Better braking due to 50% more contact patch and braking components on front axles.
Better grip.
Less understeer than conventional mortipolitionary designs.
Disadvantages
More tires, brake pads, rotors, wearable front suspension components to maintain.
More time intensive front tire rotation procedure (dismount and remount four directional tires on opposite side, drive tires are not able to be rotated to front due to size difference).
Added weight and steering effort result in less steering feedback to driver than a car of comparable performance using conventional design.
Smagu prisimint, ech.. kaip senai matytas per tv, nesupykciau jei vel rodytuLukas rašėCOLONMokomasis filmukas tiems kurie nežino kas yra Turbo BOOST'as
http://www.youtube.com/watch?v=arL04K3H ... re=related
p.s. spešal fenks to Egisas.
Tai manau kokį torrentą lengviau parsipūst ir reguleriai po kelias serijas per vakarą pažiūrėtKevinas rašėCOLONSmagu prisimint, ech.. kaip senai matytas per tv, nesupykciau jei vel rodytuLukas rašėCOLONMokomasis filmukas tiems kurie nežino kas yra Turbo BOOST'as
Mmm jo...idomu kiek ten tu KITU sudauze per visa serialo istorijaKevinas rašėCOLONSmagu prisimint, ech.. kaip senai matytas per tv, nesupykciau jei vel rodytuLukas rašėCOLONMokomasis filmukas tiems kurie nežino kas yra Turbo BOOST'as
uz tokius dalykus gali gauti" premijos" bet gerai kad teisiu neatema
O as neizlebiu, as ten antitiunings, apart kad lenta isimetes i viduJuliuoshius rašėCOLONuz tokius dalykus gali gauti" premijos" bet gerai kad teisiu neatema
O baika cia kur?Wytska rašėCOLONtema vadinasi "Antituning ir kitoks automobiliskas jumoras pics & video"
cia prie baikiu gi
tame kad zaliuoja ant virsaus egluteSky'us rašėCOLONO baika cia kur?Wytska rašėCOLONtema vadinasi "Antituning ir kitoks automobiliskas jumoras pics & video"
cia prie baikiu gi
