Neperskaitytas pranešimas
Mantas » 2009 09 09, 10:09
Kai i Honda dejau LPG, keiciau visas zvakes. Senosios NGK dar yra tikrai geros, jei kam tinka ir reikia galiu duot pasibandyt. Kodas IZFR6K-11 (Laser iridium long life). Parduotuvej tokiu kaina 78Lt/vnt.
Aprasymas:
Extreme Long Life Laser Iridium Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Extended Projected Tip, Extended Metal Shell, Solid Terminal, ISO Length, Special Firing End Construction, Iridium Tipped Fine Wire Center Electrode with Iridium Tipped Ground Electrode, .044" (1.1mm) Gap, Heat Range 6.
